How to replace wi fi connector 6
I need to replace the wi fi connector cable (No 6) is there a guide explaining how to do this.
If it is the connector on the board, you need a pretty small soldering iron tip. Remove the old one with a razor blade and finesse. I have a semi write up in my blog.
这个答案有帮助吗?
The cable itself or the connector on the logic board?
If its the connector on the cable its a somewhat easy fix, all you have to do is buy a new WiFi antenna which should be pretty inexpensive.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,506
