跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
123 个问题 查看全部
Can I use an A1474 main board as a replacement?
A1475 logic boards are quite expensive, while A1474 boards seem much more readily available. From my uneducated perspective, the major difference between the two is that the A1475 has a spot to hook up the LTE antennas, and I'm sure some circuitry to process it.
Can I slap an A1474 board in there and just not hook up the LTE antennas, and use the unit as a Wifi only Ipad? The reason the board is bad in the first place is the power management chip is bad (confirmed by replacing the battery and still not being able to charge).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Yes, you can always just not connect the LTE antennas. But then, you'd just have no LTE at all, and your frame would say you had a A1475 iPad, so then you blow all chances of ever doing a Trade-In, and selling it would be a hassle to explain. But if that does not bother you, yes you can just not connect the LTE systems and use it as a WiFi iPad Air.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark Herter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 324
