跳转到主内容
The second generation Rogue is a version of Nissan X-Trail and inspired by the Hi-Cross Concept to adapt to North American market.
8 个问题 查看全部
Radio buttons on steering wheel not working
Radio buttons on steering wheel that allow you to change from one station to another work when car is simply turned on (engine not running), but don't work when engine is turned on. (Can't change from one preset station to another). Volume control works both ways and all other functions work just fine (touch screen, control knobs) in both situations. 2016 Nissan Rogue
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
Have you ever been able to change the station presets while engine is on? If not, then this is likely a factory option. If so, then it is possible that your steering switch is broken. You could try scanning for codes, just incase.
完成的
Yes, we could change the stations from the steering wheel. And the volume controls on the steering wheel still work. In fact only this one feature has stopped working. Called Nissan and will be taking the car in for repair. They had no other suggestions.
Thanks for your input.
完成的
Every time I turn left that shuts off my radio and my DVD what could this be
完成的
Dudden Jim - I would say this mostly likely a short in the wiring harness between your steering wheel and the head unit. I would check on crutchfield.com in the FAQ I believe they have a solution for this problem.
完成的
Dudden Jim - sounds like the clockspring behind the steering wheel could be bad. Any repair shop should be able to test and replace if necessary.
完成的
显示更多的2条评论
添加一条评论
7个答案
已选择的解决方案
Check to see what is displaying in the center display on the dashboard between the tach and speedometer. The channel buttons will not work if you are displaying the settings page. Try changing it to MPG display.
这个答案有帮助吗?
得分 4
5条评论:
Tom, you are amazing and right on. No one at Nissan could figure this out. Thanks so much.
完成的
Yup, have 16 rogue couldn't figure it out, was frustrating new car only 26,000 miles and stuffs not working?? So googled finally came upon this genius and was correct!!!! Even in park would not change if I was on warning page, then changed to mpg and worked immediately!!! Bravo bravo!! Thank you
完成的
I just bought a used 16 Rogue and am having the same problem - but can’t quite understand how to implement this solution? How do you make it display MPG? When I turn on the ignition, it seems to just display “no warnings”, outside temp, milage, etc.
完成的
You're a genius. This worked
完成的
Wow!!! Thanks!!
完成的
添加一条评论
That’s crazy but it worked on my 2016 Rogue! Thank you!
这个答案有帮助吗?
得分 1
2条评论:
Thanx... My 2018 Nissan Sentra SV had the same problem. Very Helpful.
完成的
USB Flash Drive and Change Songs same thing. Changed Screen. Now it works.
完成的
添加一条评论
My sourge bottom is not working on my 2012 altima .is it a fuse or something else ? Radio is working fine but not from steering wheel !! Thank you .
这个答案有帮助吗?
得分 0
1条评论:
On my 2014 Altima SL the volume will only go all the way up or all the way down and this happens in its own. It wouldn't work at all for a while . Also i can change the settings on my screen it only shows the nav can get the radio the show or my satellite radio nothing
完成的
添加一条评论
Thanks everyone! I just had my car serviced yesterday and was having this issue this morning. Fixed.
这个答案有帮助吗?
得分 0
1条评论:
2014 Nissan rouge steering wheel audio control do not work in 2014 Nissan Rouge
完成的
添加一条评论
Omg! This is amazing! That’s all it took! Genius.
这个答案有帮助吗?
得分 0
添加一条评论
Shouldn't this be a recall item since it appear all Nissans eventually have this issue
这个答案有帮助吗?
得分 0
添加一条评论
To the person that went to the Nissan dealership for service what did they do to fix it? I have a 2015 Nissan Rogue. The left side of my steering wheel Has my radio/phone controls. I noticed this morning neither are working. I did try putting my screen on MPG which is where it is now and that did not fix it. I just thought maybe since You said you took your car in for a repair and I thought maybe they told you what was wrong with it and you would share. Thanks!
这个答案有帮助吗?
得分 0
1条评论:
I have same problem with my 2015 rogue
完成的
添加一条评论
添加你的答案
Bill Luftig 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 118
总计 104,592
