跳转到主内容
加入维修社区 - 创建账户
电脑制造商联想所生产的台式机的维修和支持指南。
Power supply replacement question
I have a pc that needs a new power supply. It's a factory Lenovo, nothing fancy... I also have several old computers laying around. I want to see if I can just use the power supply from one of those but I'd like to be sure about compatibility before I start experimenting.
The first pic is the one I want to replace
Is this a viable replacement ?
Thanks for your time!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
A big thanks to everyone who responded. My machine is back up and running like a champ!
完成的
添加一条评论
2个答案
已选择的解决方案
Plug things in properly and go.the one you want to install meets the needs of the pc.if you start adding things that take more juice you will need a bigger one but they are everywhere,like ebay
这个答案有帮助吗?
得分 0
添加一条评论
If the form factor is the same and it has the same or more output power than the broken one ( it does ), and it has all of the correct connections there is no reason why it wouldn't work.
Check the molex connectors, does it have enough? Does the molex connector that connects to the board match? It most likely does.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rep Tilicus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 238
