Infrared in remote intermittently not working with TV
The past few weeks, our Vizio remote has worked intermittently. Sometimes it works fine, other times it doesn't work at all. We checked the remote with a camera, and it is putting out the signal. A universal remote also doesn't work during the time the Vizio remote stops working, so it appears to be the TV not receiving the signal properly. The buttons on the TV still work it when the remote is in one if it's non-working times. We have done the recommended steps by Vizio - change batteries, power cycle remote & TV, check for other infrared interference (including direct sunlight). We recently moved into a newly built house, which is coincidentally when the problems started occurring. Any ideas?
2条评论
It's model #M470SV. Does the back of the TV need to come off in order to check the IR receiver connection?
由 Larry 完成的
We had a digital photo frame below the sensor. Turned off the photo frame and the remote worked better. Could be the TV was busy processing the interference from the photo frame being a flickering light source (60 hz) so close by.
由 Peter Gruenbeck 完成的
