跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
Screen won't work after replacement
I replaced my screen on my iPhone 6 plus a while back, and I tried to replace a broken camera on it today. I realized before trying to remove the camera that I had bought the wrong part, but when I reconnected the screen it lit up, but stayed black. I did in fact forget to disconnect the battery when I replaced the screen. I tested it using the old screen, which worked at first, but stopped working after testing it a second time. Is there anything that can be done to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
There's no image that shows up with the screen, just the backlight turned on
完成的
添加一条评论
2个答案
已选择的解决方案
Just backlight, confirm the phone boots up by plugging it into computer and opening up iTunes or 3utools it should detect it there.
If it does, then the screen has just gone bad, has backlight but no image.
You already tried unplugging battery and reseating the cables right?
这个答案有帮助吗?
得分 2
2条评论:
The phone does boot up, iTunes recognized it and it will be late when on, but I've unplugged the batteries and reseated the cables both. It is in fact just backlight though, and the screen has worked for months before today, the problem only started after taking the screen out.
完成的
Yeah you will need to replace the screen to fix this issue.
完成的
添加一条评论
You're sure the cables are connected 100%, this can sometimes happen when they're loose
这个答案有帮助吗?
得分 0
1条评论:
Yes, I've unconnected and reconnected the cables multiple times, both with my old screen and the one I've been using
完成的
添加一条评论
添加你的答案
Lucas McIntire 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 87
