跳转到主内容
电脑制造商联想所生产的台式机的维修和支持指南。
87 个问题 查看全部
Lenovo Desktop Motherboard fuse location
I have a Lenovo Desktop Model 50-55 Type 90BG with a W8P motherboard. Is there a motherboard fuse and if so where is it located and what procedure do I use to replace it.
If there isn't a MB fuse how can I locate a replacement motherboard.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I tried to replace a quirky PSU and used a ATX 20 pin connector on new PSU through an adapter designed for ATX 24 pin to Lenovo MB connector. Now I can't get any power to the computer.
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
Here is a link to the service manual for your desktop.
Scroll to p.77 to find the part numbers for your particular motherboard (90006404 for MB FRU W8P Lenovo Part No. 14116).
If you search online using the number 90006404 only in the search term you will get results for suppliers of the motherboard.
Here is a link to just one supplier of the motherboard. It is not a recommendation to use them. It is shown to give an idea of the cost of the part. There are other suppliers (not many) online that may suit you better.
Hopefully this is of some help, if you cannot repair your motherboard.
这个答案有帮助吗?
得分 2
添加一条评论
There is no fuses installed on almost any motherboard!
What exactly is the symptoms that you are experiencing?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Al Arlitz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 32
总计 1,902
