跳转到主内容
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 个问题 查看全部
Keyboard backlight uneven after reassembly.
Hi, this seems to be a common problem... I already read a couple of reports about this particular problem with Unibody MacBook Pro's.
In two different situations I needed to remove the logicboard of a couple of MacBook Pro 15" Unibody systems (for reapplying the thermal paste). Everything went ok, but once they where reassembled with complete care and reconnecting everything (even the backlight cable that's under one of the coolers) the keyboards' backlight illumination in both systems were uneven, where the light is mostly at the center.
The first time I didn't notice it (wasn't so pronounced) and passed it by, but now that I did this procedure again in another system, I realized that I must be doing something wrong when reassembling.
Any suggestions? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi again, it wasn't the cable. IMHO it's very easy to re-attarch this cable. It has just 2 contacts. The problem was that I moved the backlight's plastic background a bit (maybe yanked the cable while disassembling). This "plastic background" is where the LEDs are connected. So I disassembled all again, lightly pressed the zone where the LEDs are attached and presto! Working perfectly again! Thanks!
这个答案有帮助吗?
得分 1
1条评论:
The backlights plastic background? Not sure what you mean there. I have the same problem but its a used system so I cant tell if it was already damaged or was done when I reassembled it.
完成的
添加一条评论
The keyboard cable is actually a very difficult cable to re-attach. I'd suggest just pulling the bottom case off again, unplug the cable and try it again. I've personally not seen the backlight be uneven after I've reassembled them... but I'd start there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
audio01mail 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 2,732
