跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
No Light on screen totally black 5s
Hi,
The home button on my iphone 5S was not working so I thought I would open it up and have a look. I wasn't able to fix it so I decided to close it again but the screen was just black although it did vibrate and it could receive calls ( i just couldnt see anything on the screen).
I decided to open it again and check the connections from the LCD screen to the phone, I took all 3 of them out and put them back in but that still didnt work. I did notice that when I pressed the switch off button, the light did come on the actual LCD screen but just not on the phone. Also when I re fitted the LCD wire to the phone, it made a vibration. All the connections seem fine and the backlight does come on. Can anyone help me as to how I can get the actual screen get the light and touch. thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
You might of scratched something in the screen and broke it. So the best bet is to buy the ifixit 5s screen replacement kit.
这个答案有帮助吗?
得分 0
1条评论:
thanks i will resort to that after disconnecting and reconnecting the battery
完成的
添加一条评论
Did you unplug the battery before unplugging and plugging in screen cables?
If not:
1. Unplug the battery
2. Unplug screen cables
3. Plug back in screen cables
4. Plug back in battery
5. Plug back in home button cable
6. Turn phone on again.
If still same issue, screen needs to be replaced as the screen has gotten damaged. You are seeing backlight but no display which usually is a bad screen.
这个答案有帮助吗?
得分 0
1条评论:
Hi, No i didnt unplug the battery but I will try that. thanks
完成的
添加一条评论
添加你的答案
has 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,311
