跳转到主内容
加入维修社区 - 创建账户
Xbox One S 是微软于2016年8月推出的电视游戏主机。它是 Xbox One 的改款升级机型。
Eject button not working
What would i need to replace for the eject button to work again?
Currently dose not do anything when pressed have to eject manually thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I also had this problem but it got resolved automatically after 5 days
完成的
添加一条评论
1个答案
最有帮助的答案
So I have just managed to solve this issue myself for a customer.
The problem with this one was that the connector for the eject/power/BIND cable on the RF Module PCB board was damaged by someone that had previously been in the Xbox.
If a disk will still work in your xbox, but the eject button just doesn't have any signs of life/make any noises when you press it, then this is not a problem with the disk drive itself.
It will either need the RF Module PCB Board replacing, or the Eject/Power/BIND cable replacing. Best way to find out which is to open up the xbox and look for any signs of damage on either (a tear in the cable, or if the connector looks as if it is coming away from the board)
Hope this helps.
R
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jake Kay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 2,643
