跳转到主内容
Repair information for Bosch dishwashers.
40 个问题 查看全部
Bosch Dishwasher not draining - NOT A NORMAL FIX - please READ!
I have this 5 years old Bosch SHE4AP06UC/06. It is not draining. After several minutes when water is pushed in, the machine stops and shows CLEAN. The bottom is full of water. yes, I checked the filter, all hoses, no obstructions - all looks OK. Then I bought a Drain Pump and replaced the old one. Still no change.
I did something else to check if the Drain Pump works: I lifted the floater on the inside bottom. After several clicks the Drain Pump starts working...BUT...it's pushing water inside - NOT OUTSIDE thru the hose and into the disposer! So in the filter compartment I see a jet of water that is pushed by the impeller inside. The Drain Pump is new?
Any thoughts please?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
FOUND THE FIX:
At same time when machine stopped working I replaced the Food Disposer.
Did not realize that you need to knock out the knock out plug that is in the pipe where the hose from dishwasher gets installed. This is why the Drainage Pump was not able to pump OUT of the machine.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for posting this. It allowed us to fix the issue (after we bought a new dishwasher! We needed a new one anyway).
完成的
添加一条评论
I have the same, exact problem, except that can’t be my solution - I have no garbage disposal. The drain tube is open, the waste water pipe it goes to is open, there’s no obstruction in the pump basin, and the impeller turns freely. The pump will cycle a few times without draining the tank and throw an error code (E25). In Customer Service Mode, it gets to step one and throws E25. Any ideas? The pump turns on, so its microswitch works. Maybe a broken solder joint on the bread board?
这个答案有帮助吗?
得分 0
添加一条评论
When the flood transfer is activated the dishwasher will now no longer fill or wash however best drain. A story signal the unit is in flood mode is in case you open the door, the unit remains walking. Now it can sound just like the wash motor is walking however in truth it’s the drain motor.
To remedy this difficulty the dishwasher wants to be pulled out to dry the water so the flood transfer is going down. Once the unit is out the facet panel comes off giving get entry to the flood transfer and different components. Drying the water out of the bottom pan will allow the gadget to fill with water again. At that factor, you will want to observe the unit to decide wherein the leak is coming from. Repair the leak frequently instances a hose or unfastened connection below and your lower back in business.
Check the pump for any overseas gadgets and dispose of any deposits. Ensure that the pump impeller can circulate freely. Replace the pump cowl and make certain that it engages efficaciously lower back into the role until it clicks. The pump covers on a few fashions may be eliminated with the aid of using the usage of a guide screwdriver (in no way use an electric powered one).
Any obstructions have to then be eliminated with inside the equal way. Place the clear out lower back into the role, making sure the arrows align. Replace the basket and your dishwasher is prepared for use.
If you want to clean the water status at the lowest, here’s the way to drain a dishwasher. Line the ground below the dishwasher with towels or newspapers. With a measuring cup or a big ladle, scoop the water from the lowest right into a bowl or the sink. When the water turns into too shallow to scoop, take in the ultimate moisture with fabric or paper towels.
Always make certain that you’re the usage of the proper kind of dish detergent according to manufacturer’s directions, to keep away from clogging the drain. And taking a few preventative steps to preserve your dishwasher walking easily also can assist you to keep away from a few drainage issues.
这个答案有帮助吗?
得分 0
添加一条评论
Did you invert the polarity?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
GTC 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 36
过去 30 天: 189
总计 14,334
