跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for LCD e-writer tablets manufactured by Boogie Board.
Parts of my Boogie Board are grey!
I have a Boogie Board (model 01582801516) and in one of the corners there's a large grey spot that won't go away.
Why is it like that? How can I fix it if it CAN be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
Actually, Found this: Boogie Board won't erase
这个答案有帮助吗?
得分 3
添加一条评论
sounds like screen burn in. and probably needs a new LCD. how long have you owned it?
这个答案有帮助吗?
得分 2
5条评论:
@captainsnowball boogie board tablets are cheap e-ink displays with a limited battery for clearing what you've drawn on it. After the battery runs out you can't clear it anymore. It's cheap and designed to be disposable. Sometimes points on the screen get dots that cannot be erased. Perhaps because someone pressures the screen to hard.
You should always google the device before answering a question.
完成的
I took a look at it. I have a kindle and I beleive its the same mechanism. but as he said, he cannot get it to go away. presumably he tried turning it on.
完成的
No Aiden, you don't turn it on. It's a very basic device. You write something on it, it stays there until you hit the clear button at the top which refreshes the screen once. It's a totally analog device.
完成的
I've owned it for a few years. I think I got it when I turned 10?
完成的
Grey blotches can appear if the top LCD layer separates from the rest of the LCD, usually due to physical stress like a bend or impact from dropping it. No idea if it's repairable of worth repairing.
完成的
添加一条评论
why does my boogie board have grey dots, WHY?!
这个答案有帮助吗?
得分 0
2条评论:
Mine has blue fading happening around the edges...
完成的
I got the blue fading in the upper corners. I am not able to erase, either. I have replaced the Cr2016 batteries - no the solution here. I have a greenish tone over the entire screen and I can make marks on this green area, but I am not able to erase anything. I can gentle scroll over the grey marks to cause a uniform green tone color - then I can make new grey marks over this area which very very slow fade significantly. I am assuming this display is totally wasted. This failed boogie board seems to resemble my water Buda Boards that softly fades as the water brush marks slowly evaporated.
完成的
添加一条评论
添加你的答案
Morgan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 32
总计 3,878
