跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
Gluing the capacitive buttons to the back of the Screen assembly
Hi!
I just finished disassembling the S6 of a friend for a screen-replacement and noticed that I damaged the cable going from the daughter-board to the menu button. Since the buttons are hard wired to the daughter-board I ordered a replacement online. The replacement is in used condition (i.e. comes from another phone) and doesn't include any adhesive to glue the buttons back to the screen assembly. I have no idea what kind of adhesive tape/liquid to use.
Does it have to be electrically conductive?
What thickness should I go with if I choose a tape?
Thanks for any help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
When you replace the charge port (which has the menu buttons on it) if you sit the cables down in their little cut-out positions and press the screen down that will be enough. The screen will put pressure on the buttons and it will be fine.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
buy a new charge port and it will have adhesive, why did you buy a used 1 when they are cheap new
这个答案有帮助吗?
得分 1
4条评论:
I bought the part in used condition because I wanted to makes sure it is an original part. The iFixit online store in Europe does not sell the part so I looked elsewhere. All the new ones seem to be knock-offs and I read mixed reviews on quite a few "original quality" parts on ebay and amazon. Any tips on the glue?
完成的
something like this should be fine https://www.ebay.co.uk/itm/3M-1mm-x-50M-...
完成的
Great, gonna try this one out. As far as I see there is no electric conductivity or anything special about it. Are you confident that the buttons are going to work as expected?
完成的
should be fine as i think the touch is detected from the light being covered with a thumb or finger
完成的
添加一条评论
添加你的答案
Filippos Bamopoulos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 145
