跳转到主内容
The HP Flyer Red is a laptop created by Hewlett Packard which was released around December 2014.
My computer suddenly turned off and won't turn back on..
I recently bought the HP Flyer Red laptop and it has been working great for about a month until I cut the camera on and it suddenly turned off 2 days ago and won't turn back on. I tried charging it and taking the battery pack off. It came on for a split second and turned back off. I tried it again today while charging it and it came on but went to a dark gray screen with just the mouse pointer showing. What could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
What do you mean by "cut the camera on"?
What OS is installed in the laptop?
Have you tried starting the laptop with the battery removed and only the charger connected?
If it starts OK allow it to boot all the way to the Windows desktop, let the HDD activity settle down a bit and then shutdown the laptop in the normal manner.
When it has completely shutdown, switch off the charger and disconnect it from the laptop
Reinsert the battery, reconnect and switch on the charger and then turn on the laptop.
If it starts OK allow it to boot all the way to the Windows desktop.
Check the battery charging status and if the battery is charging allow it to fully charge before switching off the charger and disconnecting it from the laptop.
这个答案有帮助吗?
得分 1
2条评论:
My camera turned on and now won't turn off
完成的
Hi @Shania Bacchu,
Not quite sure what you mean.
Are you asking about the webcam in your HP Flyer Red PC?
If so what is the exact problem?
What program are you using the camera with etc?
完成的
添加一条评论
添加你的答案
krcayson1982 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,478
