跳转到主内容
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
Why the Microphone doesnt work with loudspeaker?
Hey ...
got a Galaxy Note 5 and the title says it all !
Microphone works great with a normal phonecall but with video calls or a call with loudspeaker my voice is gone ?!
Is it a Hardware Problem ? How many Mic's this Note 5 got in it ?
thx 4 reply !
bye
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi @odesu ,
There are two microphones in the Note 5.
The 2nd one is a noise cancelling microphone but I believe that it is also used when in loudspeaker mode.
Here is a link to the ifixit Samsung Galaxy Note5 Teardown guide.
In Step.12 you will find the location of the noise cancelling microphone.
Here is a link to just one supplier of the part. It is not a recommendation to use them. It is shown to give an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for galaxy note 5 noise cancelling microphone part to get results.
Before you go to replace the microphone or even to check that it has come loose etc, try starting the tablet in safe mode just in case, for whatever reason, a downloaded app may be the cause of the problem. If it works OK in safe mode then the trick is to find out which app is the culprit.
I don't know your phone but check at the top of the phone if there is a voice inlet hole (similar to what is on the bottom of the phone) and see if it is blocked. Use a strong light and a magnifying glass to check. If there is a voice inlet hole and it appears blocked (or even if you can't tell) use a vacuum cleaner to try and clear any obstruction. DO NOT use a probe to clear the hole as you may damage the microphone.
这个答案有帮助吗?
得分 5
添加一条评论
I found the problem go to settings under sounds and select allow to play with hearing aids.This turns on the speaker on the bottom too and allows loud sound.Otherwise it would only play sound from the speaker on top which is used in calls and is not loud.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Odesu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 17,924
