跳转到主内容
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 个问题 查看全部
Horn button under airbag is depressed.
The horn kept on going one day so I took out the fuse. Bought a new one and it did the same thing. And the last thing I can think of is the horn button being stuck down. What do I buy and how do I replace the horn button under my steering wheel under the air bag.
Pontiac Grand Am 2003. Under airbag.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
When you say that you took out the fuse, did you mean Fuse #43 in the engine bay fuse block?
Have you tried replacing the Horn relay (Relay #21) in the engine bay fuse block, with a similar relay found in the fuse block (if there is one) to prove that the relay is not the problem, instead of the horn button.
Here is an image of the engine bay fuse block taken from this website showing the location of the horn relay (red) and the horn fuse (purple)
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 2
3条评论:
I did take out that horn relay under the hood, I did not know a broken horn relay could cause the horn to honk continuously. I will buy another relay and see if that fixes it.
完成的
Hi,
Did you try swapping in another similar relay from the fuse block into the horn relay position to see if it stopped the horn sounding all the time? Save you the cost of a new one if it isn't the relay that is the problem
完成的
I have the same problem. it is the switch membrane or "horn switch" The membranes are stuck together. It is part of the air bag module.
完成的
添加一条评论
添加你的答案
Smundin34 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 2,137
