跳转到主内容
Portable wireless speaker with a built in microphone. Released January 27th, 2014.
36 个问题 查看全部
Can someone identify this component Please... A6 A
JBL Flip 2
A standard charging port replacement went south when the centre screw removed this component from the main board.
Its designation is D9 on the board and printed with A6 A, I believe its a Diode but not sure what other properties it has.
my knowledge on components is that of a three year old monkey.. I can replace and solder, but how or why it works is beyond me.. some sort of magic I presume..
Its situated next to the centre screw hole on the main board, and without this the unit wont turn on or charge unless you hold the power button down, when you release it, the speaker turns off with a loud pop..
Any help on this would be much appreciated..
Many Thanks
Paul
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hey Paul,
I don't have this board but you're exactly right - that is indeed a diode. Diodes pass current in one direction and there are several types. Some google searching for A6 diode indicates that it could be a BAS16 or a BAV series high speed switching diode. There seem to be a few diode manufacturers / types using this code. Check with Mouser electronics or other supplier as they could probably help you find a replacement.
BAS16 datasheet
这个答案有帮助吗?
得分 0
添加一条评论
try something like this
https://www.digikey.com/product-detail/e...
make sure you get it in the correct direction
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul Tulip 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 153
