The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
Alison McCaulley @allydawn
声誉积分: 1
发帖于: 2018年2月23日
Rear Brake light out and both brake a front blinkers work on and off with the light flickering fast when it does work. Help
这是一个好问题吗?
sm_vulkus @vulkus
声誉积分: 2.6千
5
4
发帖于: 2018年2月24日
OhhhK. When your indicators flash fast, usually that means that one has blown or has a fault. Or it could be your indicator relay.
If the rear brake light is out and it isn't the bulb, then it can only either be a fuse, relay or wiring. I'd check your fuses first.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 103
