跳转到主内容
The Chevrolet Silverado, and its mechanically identical cousin, the GMC Sierra, is a series of full-size and heavy-duty pickup trucks manufactured by General Motors and introduced in 1999 as the successor to the long-running Chevrolet C/K line. The Silverado name was taken from a trim level previously used on the C/K pickup truck from 1975 through 1998.
135 个问题 查看全部
temperature sensor on the passenger side of 2005 Chevrolet Silverado
My passenger side vents are blowing hot air when the AC is running & fully set on cold. The trick of removing a battery cable works as many times as it fails. A parts store man said there are 3 sensors beneath the dash and a simple lubrication spay wight work. Where they actually located and how do I get to them?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Spraying your sensors with lube won't do anything. I suspect he meant 3 actuators, which power the flaps for hot and cold air, direction and demisting. The lube inside these often dry out, leaving them prone to incorrect working conditions. Try this YouTube link, as it tells you where they are and how to fix them.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Geary Garton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 50
