跳转到主内容
Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
66 个问题 查看全部
Green lines across my images
I purchased a Canon 70D over eBay and on all the manual settings, the images have two solid green lines across them. This could indicate a possible sensor problem, however, if I shoot on Automatic the lines are not there - could this be possible?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Had a similar problem with a 5D MKIII, replaced the Sensor Ass'y, Main PCB & Mirror Drive PCB with test parts and didn't fix it, figured Main PCB was corrupted so downloaded and installed Magic Lantern (only on the memory card) ran the test's it comes with and fixed !!!
这个答案有帮助吗?
得分 0
添加一条评论
Change the aspect ratio of raw images to 3:2 or the default that it came with and you can crop it latter
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nell Delport 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 1,078
