跳转到主内容
加入维修社区 - 创建账户
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
Reset windows installation error
I did a factory rest on my tablet and every time it tries to restart and reinstall windows, it throws an error message that says “The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install windows, click ok to restart the computer, and then restart the installation.” When I choose “ok”, it cycles back to the same error message. What do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Windows? This is an Android tablet! How on earth did you get Windows on here?
完成的
I keep doing the same thing,what I do when if Occur
完成的
添加一条评论
2个答案
最有帮助的答案
1) On the same error screen press SHIFT+F10 and it will open up a black Window. (a command prompt window)
2) In  the black windows type the word "regedit"(without the inverted commas and hit enter. That will open the registry editor.
In the Registry Editor..
Browse to....
HKLocal machine/SYSTEM/SETUP/STATUS/ChildCompletion, and after highliting childcompletion,on the right hand side check for setup.exe. if the value is 1 change it to 3.(by double clicking on setup.exe and changing the value shown in the box).
Then close the registry editor and then also close the black window.
Then click on OK for the error and the computer will restart and the installation may complete.  try it and if the installation failed, check out these methods.
这个答案有帮助吗?
得分 6
7条评论:
how do i pres the SHIFT +F10 because the is no keyboard display
完成的
usb keyboard worked for me:-)
完成的
Thank you Albert. it worked for me on Surface 7.
完成的
Thank you so much, worked instantly!
完成的
It goes to loading screen at 64 % than restarts been doing it for several hours
完成的
显示更多的2条评论
添加一条评论
I think this fix also worked for me. Windows is installing its at 44 percent. Hopefully it keeps going!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chrissy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 4,278
