跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone Not Turning On After Using Cheap Wall Charger
I had a fully functioning iPhone 6s until a few days ago. Will traveling with my family, my dad brought a wall charger that we later found to be faulty after my phone died. The minute I plugged the charger into the outlet to charge my phone, it first froze and then died.
I have tried multiple steps to try to bring the iPhone back to life. I would do a hard reset, but that wouldn't work. Honestly, my iPhone has no signs of life thanks to the faulty wall charger. What can I do to fix this problem? Is the logic board officially fried and therefore unusable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Could be one of many things or could be a combination of them:
- Charging port and battery blown (You would need to replace both at the same time to get the phone to work properly)
- Battery gone bad from faulty wall charger (Battery just needs to be replaced if that's the only part faulty)
- Charging chip, power management chip gone bad (Tristar, board-level / microsoldering repair)
- Main processing chip gone bad, if this is the case the phone is basically paperweight.
- One or more capacitors near the main processor chip shorted (in this case they usually get removed and if needed replaced as well).
这个答案有帮助吗?
得分 1
添加一条评论
Ben I'd say you've gone a little too far :)
Using a non-original charger causes a malfunction in the motherboard that is connected to the U2 component.
Throw away the charger, go to a professional lab to replace the component.
Use only original charger % cable! also in the car(greffen approved by apple - car charger very good!)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Makhwarand Khan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 207
