跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
How to fix pink lines that appear when discrete GPU is used?
I have a 15" Early 2011 MBP that comes with an integrated Intel GPU and a discrete AMD GPU. Whenever the dedicated GPU is used, some pink lines appear on the white parts of the screen. However, the integrated GPU works just fine. Additionally, when I connect my laptop to an external display, I don't see the pink lines on the external display, but I see them on the laptop's screen.
I understand that Apple had a program to fix this issue, but that program does not cover my laptop anymore. Additionally, I have seen similar questions on the Internet, but I'm not sure whether their problem is similar to mine.
I have also seen different solutions such as replacing LVDS cable, logic board, etc. Has anyone tried any of these solutions?
P.S.
You can see a few pink lines at the top of white area and a big pink area at the bottom.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Yes this is most likely the all gpu error, However it may not be, one good thing is that almost all the issues with the gpu will show up on a diagnostic. if you could run one of these for me and get back to me with any errors that show up...
to do this switch on the Mac and press the alt + D key hold this until the diagnostic screen appears or you get the globe then select your language and start the test. any errors will appear in the log at the end of the test.
Further more if this is a problem with your GPU almost all fixes are temporary as the gpu is soldered to the main board so the only thing you can do is replace the board... However apple replaced the boards with the exact same gpu and solider that was in they never revised the board there for the problem will only re occur there a a few workarounds I can walk you threw once we know what the problem is.
这个答案有帮助吗?
得分 1
17条评论:
Thank you for your reply. I ran the diagnostic a few weeks ago and it didn't show any errors.
完成的
This is most likely your lvds cable you could try reseating it at the logic board to see if it makes a difference they have a really small bracket holding them in that could come free over time.
The reason I think its the lvds is that if it was a gpu issue you would definitely see them lines on the external display
完成的
Thanks. I'll try tightening/replacing the cable and will report the result here.
完成的
It is your GPU. The LVDS cable NEVER FAILS!! And AHT NEVER shows GPU errors... Do not touch the cable. It is not your issue.
完成的
@tcrs_circuit if you read his post he is not receiving the lines on an external display when using an external display you are automatically are using the discreet GPU so if he isn't getting the lines then it isn't his GPU please fully read query's before answering.
完成的
显示更多的12条评论
添加一条评论
Go to
system preference> displays> where it says Display and colors( select colors) > calibrate> continue>uncheck “use native white point” > move the slider till the pink disappears> continue by saving the calibration with whatever name you like
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 3,147
