跳转到主内容
Repair information for the Brother MFC-J6920DW wireless, multifunction inkjet printer. Model number: MFC-J6920DW. First available on Amazon in September of 2012.
23 个问题 查看全部
prints very light when initiated from the PC but makes copy ver
Prints very light when copy is initiated from the PC but makes very clear copies when copy is from the printer (glass). I have checked and unchecked the color print option without success. Any tips on how to fix?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @ooa ,
What OS is installed in the computer?
Have you checked the other printing preferences in the printer properties?
Here is a link that may be of some help.
Select your OS and then select either Advanced printing methods (Windows) or Set print Options Macintosh (dependent on your OS), and then select any link that mentions quality or colour to see if the adjustments resolve the problem.
If adjusting the settings does not resolve the problem, check that you have the Brother printer drivers appropriate to your OS installed and that you are not using the "generic" OS drivers for your model printer.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
okey O 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 345
