跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
iPad Air says “Not Charging” sometimes but often
I’ve replaced the dock connector and u6000 (1610a1) twice with same symptoms returning.
When plugged into a charger it either charges fine or only charges at half the normal current draw and top right displays “Not Charging”
I have two iPad Airs doing this. Anyone ever see this before and/or have a solution?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I apologize for the dumb question but this may benefit others who stumble upon this question. Which charging brick are you using? If you are using the small square one that is typically packaged with iPhones, then this is exactly what you will see. For the iPad, you need to use the larger 12W charger.
Now assuming you are using the proper charger, have you checked PP3V0_S2R_TRISTAR & PP1V8_S2R_TRISTAR? You'll also want to check the VCC_MAIN circuit (Q8104) as well as the voltage protection circuit (Q8123).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
curious one 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 357
