跳转到主内容
MacBook, MacBook Pro, 和 MacBook Air 交流电 电源适配器。
65 个问题 查看全部
Power adapter working only 30 seconds after repair
Hi there,
I replaced my MacBook Air adapter's wire following this guide, only I installed a replacement wire instead of keeping the old one.
I had already done it once and hadn't had a problem.
Since I did, adapter won't charge for more than about 24 seconds. After that time, it goes completely down, LED is off, computer doesn't see it at all. Consistently.
I have to unplug it from the wall and plug it back in to make it charge again. It consistently works. I don't need to wait, unplugging it and plugging it back in instantly is enough.
Conversely, unplugging it from the Mac and replugging it doesn't change anything.
However, if I unplug the adapter from both the Mac and the wall, then plug it to the wall only, wait 30 seconds, and then plug it to the Mac, it works (for 30 seconds though).
I can't detect any heat during these 24 seconds. No sound either.
As a corner case, if I leave the computer charging while closed, then it works fine. Also, in some cases it works fine too, mostly when it has been charging while off for a while. It seems that after about 40 minutes charging while off, if I turn it on then it continues charging without problem.
I have tried both the "duck head" as well as the extension chord. I also tried on several power outlets, including through an inverter with its own battery.
One potential noteworthy thing is that I am using this 45 W MacBook Air charger on a 60 W MacBook Pro. I had no problem before though.
Additional information:
  • I couldn't find the wattage in System Information, however based on information on Apple's website, my Macbook requires a 60 W power supply.
  • Based on the information about the replacement wire, it seems to be compatible with both 45 W, 60W and 85 W adapters.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
What you describe seems, some overload protection is tripping. Removing and reconnecting power supply to its load (MacBook) is needless, because power supply remains in tripped / shutdown state. Substituting AC connection ("duck head" or cord) is needless, because form of AC connection is not important.
'I installed a replacement wire instead of keeping the old one.'
Do you know, what kind of replacement? What specific type of MagSafe tip/plug? If your plug identifies as 60W or 85W, then it is no wonder that your 45W supply is overloaded. You can use 'System Information.app' (or 'System Profiler.app') to find your plug's identity. Open 'System Information.app', view 'Power' (subpage of 'Hardware'), look under heading 'AC Charger Information:'. What 'Wattage (W)' is reported?
Addition 2018-03-03: For an idea of what 'AC Charger Information:' looks like, a clue as to what to look for, you can look at this screenshot hosted on Apple Support Communities. Pictured is a full 'Power' report section; near bottom is 'AC Charger Information:'. Whoever snapped this image had a 85W plug.
这个答案有帮助吗?
得分 0
3条评论:
Thanks for your answer !! It seems to go indeed in the direction that things point to. My replacement wire is an L-shaped tip. I couldn't find the wattage in System Information, however based on information on Apple's website, my Macbook requires a 60 W power supply. And based on the information about the replacement wire, it seems to be compatible with both 45 W, 60W and 85 W adapters.
I guess the overload protection assumption makes a lot of sense. The only thing I don't understand yet, is why I didn't observe this behavior previously, with the same adapter and its original wire.
完成的
You need to check what the MacBook identifies the charger as as each magsafe plug has a chip embedded in them to tell the laptop what wattage charger it is.
As said in the answer, in system information application under power area.
If the cable doesn't at least match or be lower than the charger spec then the charger wont work properly.
完成的
Shape is not important. (It could be curved "figure J" or oblique "figure 7".) Sellers spew lots of nonsense. (I've fallen for plenty of marketing lies.) Yes, any MagSafe stuff is "compatible with" other MagSafe stuff, for varying definitions of "compatible". In your case, it is "compatible enough" to charge, but is inclined to overload when computer runs while charging.
This person's situation is converse: ey replaced a 85W plug with a 60W, so eir 85W power supply will be underutilised. "Compatible" does not "get the most out of it". Change 85W magsafe broken cable with new one, but detected as 60W
完成的
添加一条评论
添加你的答案
John Dupont 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,102
