跳转到主内容
The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
108 个问题 查看全部
LCD ribbon cable connector missing
The black clip that holds the LCD ribbon cable snapped.
Is there a way to replace that piece and what is the part number please?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
To replace the clip requires microsoldering . iIt may be easier to try to repair the clip if its not badly broke . the locking mechanism is held in place by two small nubs at each side of the clip that go into the side of the base . if the nubs arent broke off you should be able to get the clip to go back on . use a pair of tweezers and it may help to have a magnifing glass to see what your doing . If this brings no joy you can also try wedging a small piece of plastic into the joint to force the ribbon cables down onto the pins then taping everything in place . If however you want to solder on a new clip you may want to take it to someone who does this kind of work . Hope this helps
这个答案有帮助吗?
得分 2
9条评论:
Do you know I could purchase the clip?
完成的
The black clip is what is missing. The terminals on the ribbon cable face upward so I would to put the shim (?) under it to make the terminals make contact.
Any ideas on what would be best to use?
What type of tape would you recommend ?
完成的
piece of plastic from a guitarpick or credit card will work you will need to see what works best just dont cover the pins , as for tape black electical tape will work or kapton tap can also be used but nothing conductive . As for places to get parts I use digikey.com ,AliExpress.com, dhgate.com Ebay and Amazon to fined what i need
完成的
I had the exact same problem, stuck some tape to bottom of lcd cable at the end so it made it fatter (so it lifted it up) this made contact now display is working
完成的
Is there any guide on how to replace the lcd flex cable? How on earth do u disconnect the other end? Does the screen have to be removed?
完成的
显示更多的4条评论
添加一条评论
Yes I have to agree with the method of placing black insulation tape on the back of the main ribbon.
Ensure not to overlap the edges.
I used one piece on one tablet on another I had to double it up with two pieces Once screen is active hold the ribbon in place with some tape going across the battery to keep it in place.
这个答案有帮助吗?
得分 2
3条评论:
I hadn't read this solution before reaching to the same conclusion today. I had to open the tablet as the LCD cable had become loose. During this process I broke the black plastic clip and then the LCD cable wasn't making proper contact. Just a bit of tape under the cable, some more tape over the battery to secure it and now it's all good again
完成的
It will be better to have a youtube videos explaining it...badly need it
完成的
Can't find videos
完成的
添加一条评论
添加你的答案
D Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 26
总计 6,471
