跳转到主内容
The Motorola Moto Z Play (model number XT1635-02, XT1635-01 and XT1635-02) is a droid smartphone that was released in September 2016. The Moto Z Play can be easily distinguished by the word “moto” placed at the top and the square home button placed at the bottom of the front of the phone.
58 个问题 查看全部
No touch response after screen replacement
I replaced a screen with a cracked LCD. After replacement touch is unresponsive. During startup, I am prompted to enter my password and after a few seconds I can do so. Once started up, the screen comes on, but I can not unlock the screen. It appears to respond to touch, because the notifications change color when selected, but it does not unlock or prompt me to put in my code to unlock. Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Only works now if I'm touching the screen with two fingers
完成的
hey did you get a solution to this? I am facing the same issue
完成的
添加一条评论
1个答案
最有帮助的答案
Hey Casey!
Incompatible screen. Moto Z Play is a difficult one to find good parts for. Have to make sure the flex configuration is exactly the same as on the original or else it either doesn't work or only works with two fingers like you mentioned.
这个答案有帮助吗?
得分 1
1条评论:
Great! I am having the exact same issue... Anything that can be done to fix the two finger operation?
When I ordered the LCD screen on eBay, the description said the part was for Moto Z Play XT1635. There was no -01, -02, -03 suffix. So I believed it would work with all of them. I have XT1632-02.
完成的
添加一条评论
添加你的答案
Casey Reynolds 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,138
