跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 个问题 查看全部
Screen dims then turns off after certain angle
Hi, my 12" Macbook (2015) has developed a problem where the screen turns off after opening beyond a certain angle (at the moment about 60 degrees). It works normally if I only open the screen slightly or with an external display, but when attempting to open the screen beyond a certain point it starts to dim then completely turns off.
When it turns off the laptop still works with an external display and sound still plays - just no image at all on the monitor. Closing the laptop to put it to sleep then reopening gets the screen to turn back on.
Any ideas what might be the problem or if this is fixable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This definitely sounds like the display cable is being pinched by the case. I would recommend keeping the laptop closed until you are ready to fix the issue, as if the cable keeps getting pinched it can rip or tear.
This is fixable, you just have to use the iFixit guides to get to the Display cable, and then adjust it so that it is no longer being pinched.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Liam Newton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 637
