跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Phone has a mind of it's own after screen replacement
I have replaced many iPhone 7 screens now but I'm having a high ratio of phones coming back to me because of issues with the touch after the replacement. I've just been contacted by another customer saying that the screen has a mind of it's own, pressing button on it's own etc.
I'm buying what I consider to be good quality screens, certainly not cheap nasty ones. I'm installing correctly and testing before I give back to the customer (with the customer present) and all works great but within 24 hours they develop issues.
Can anyone offer any advice/solutions.
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Hi,
If you’re not using OEM/Original or refurbished screens, you can have these issues happen, as copies are pretty unreliable.
The cables on the 7 series are also very fragile, so any excess bending can cause this to.
Another thing to look out for, is any issues with the Audio IC, this can cause touch issues, freezing, etc.
这个答案有帮助吗?
得分 2
添加一条评论
Repeated problems probably indicate a poor supplier. You don't say where you got them so I can't comment but I would certainly contact them and discuss the issue. You could also try some better quality screens to see if the problems go away.
这个答案有帮助吗?
得分 2
添加一条评论
Does the problem persist if you put back the original LCD's? If so then check the audio IC as @gedo1992 has said. If it does try replacing the IC.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Soop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 319
