跳转到主内容
The DZ09 is a Chinese smart watch with basic features and the ability to make calls. These can be as cheap as $10! (Yes, you read that correctly!)
90 个问题 查看全部
Dz09 cards, got them from my phone. Now saying the SIM card is locked
My sister got me a DZ09 Bluetooth Smartwatch/Phone for Christmas. I tried going on Facebook, the Browser. twitter, and What's app. It said I needed a Valid SIM and SD Card. Now, I unmounted the SD Card from my Alcatel OneTouch Elevate, and also took the SIM Card Card. Luckily, it's not saying anything about the SD Card now. But one issue. It's saying: "The SIM Card has been locked. Please try Power Cycling the Device. If problem persists, Call Customer Support." Someone please tell me why. Is it because it's the wrong sized SIM Card? Something's messed up? Is it because I'm not with a Carrier for my Phone? On the front of the SIM Card, it says Sprint. Please help me, I would appreciate it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
6条评论
not call to any number
完成的
Hi @umair abbasi,
Has it ever worked?
Is the SIM card from a service provider that has a 2G network?
The watch does not work as a phone when trying to connect to a 3G or 4G phone network.
It works on a 2G network ONLY
完成的
I am able to call and text from my Dz09 smart watch but I cannot access the internet or apps and mine keeps saying insert valid sim and next to the battery display is says insert sim....
完成的
Low tech watch###########################!!!!!!!!!!!
完成的
HELP.... IT WONT LET ME CALL, or TEXT I DONT KNOW IF THEY EVEN SENT ME the RIGHT SIM CARD
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
Hi @betasqaud001
Are you trying to use the phone's SIM card in the watch?
According to the user guide (scroll to p4) the DZ09 only supports 2G GSM 850/900/1800/1900MHz.
If the SIM's phone service provider doesn't have 2G in your area it won't work.
这个答案有帮助吗?
得分 2
添加一条评论
In addition maybe you need to desable sim password in your mobile phone before you use it in the smartwatch.
Es conveniente desabilitar la clave de la tarjeta sim en un móvil antes de usarla en el teléfono.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alex Edelen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 8,178
