跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Where is this rubber thing supposed to go?
While I was replacing the iPhone 6s Plus Lightning and Headphone cable a little rubber thing showed up as I removed the Headphone assembly from the phone. I figured out that it came from the headphone jack, but I don’t know where to put it back.
Does anybody know?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I don't know what it is, but I can tell you it is a waterproofing gasket of some sort.
完成的
添加一条评论
2个答案
最有帮助的答案
its supposed to thread down on the new AUX port.
Its not 100% necessary to have, but thats where its going to be.
这个答案有帮助吗?
得分 3
2条评论:
Where exactly is it supposed to go on the AUX port? Which way?
完成的
It should match up with the iPhone housing headphone port hole, you can experiment which way it sits against the housing.
完成的
添加一条评论
That is the gasket that fits over the end of the headphone jack. To put that back on you will have to go through the procedure to replace the lightning connector assembly which includes on it the headphone jack and two microphones.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel Kendel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 92
