跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
CPU getting really hot and barely charging
Ive just recently changed the battery on my iphone and the LCD and it was working perfectly fine, however when i changed the battery i teared the flex cable for the silent swtich. So I replaced the whole chassis and put everything back into place and replaced the flex cable but for some reason the phone turns on when I put the power cable in but does not charge/goes up a few % but does not show the lightning icon. The CPU gets really hot and the flashlight does not work.
I have removed the EMI shield for a better view of the circuit board.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I can also note that i have used super glue on the lock button and I dont know if thats too close to the cpu causing it to get hot.
完成的
添加一条评论
1个答案
已选择的解决方案
With so many things changed at the same time, that's a lot of variables that need to be eliminated.
Firstly, why did you change the chassis if all you did was tear the power button flex? Yet you also mentioned that after the chassis change, you replaced the flex. Was this an empty chassis or one from another device?
Fake charging is usually logic board related (Tristar) but in this case, you may have damaged the charge port flex.
At this point, you need to troubleshoot with know good parts and try only one thing at a time. Start with Lightning Port flex and battery. If you don't have access to known-good parts, you could consider asking a shop to look at this.
这个答案有帮助吗?
得分 4
4条评论:
Would there be any way to check if it is the charging port like disconnecting a connector?
完成的
If you disconnect the charging port, you won't be able to test if the charging works or not.
完成的
Would there be a way to test the charging port by using a multimeter?
完成的
Not really...
完成的
添加一条评论
添加你的答案
Harry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 262
