跳转到主内容
Why is my sim not responding?
My Zenfone 5 Sim 1 and 2 have no signal. How do i repair it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
sim contacts is not responding asus zenfone
完成的
My TCL phone does not have single
完成的
添加一条评论
1个答案
最有帮助的答案
1st clean the sims
See if this works if not try next step
2nd clean the contacts in where the sim goes
3rd the contacts in the sim tray my need to be bent upwards verys slightly to make full contact I would try a tooth pick or a plastic pick. ***** WARNING this could damage your phone BE CAREFUL ****
这个答案有帮助吗?
得分 1
3条评论:
Hi
With your option #3 wouldn't it be safer to increase the thickness of the SIM card by placing a suitably sized piece of paper on the back of the SIM card so that the pressure on the SIM reader contacts is increased?
完成的
Then you risk bending the frame and crushing the pins in further. It is better in my mind to try and return something to the way it was designed. Light pressure and a steady hand can return this to the way it was new.
完成的
Hi,
Fair enough.
完成的
添加一条评论
添加你的答案
Dhab 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 163
