跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
The phone never hold charge for more than 3 hours
before i own this phone the old owner was using many different types of chargers and the battery is killed
after that i got this phone as my own for low price i replaced the battery it charge pretty normal but in use only max 3 hours and like 10 mins if standby it can stay only for about 5 hours and 30 mins
even i used an iPad battery which is way greater the charge do not pass this limit of 3 hours in use
so please help me what to do
im also have mid skills because i fix LCD and LED televisions
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Wait a second, how did you connect an iPad battery in?
Well I know at least the iPad Mini and iPhone 5 use the same battery connector.
The issue is most likely the tristar chip going partially bad causing rapid battery drain.
To get that fixed it requires board level repair / micro-soldering.
Also you can check the battery heath.
Use either one of these methods to check your battery:
Windows PC - 3UTools
Mac OS X - CoconutBattery
Using mobile app - Battery Life
这个答案有帮助吗?
得分 1
1条评论:
okay im connectiong an iPad battery using the protection circuit of the iPhone battery protection circuit
the battery is not original iPhone battery its cheap battery in market
as 3UTools read the battery between 1200 mAH to 1387 mAH
the iPad battery rated at 6500 mAH the rate on the battery itself the iPad have 3 battries so when i took one it did not kill the iPad its still working on 2 battries
right now the iPhone battery is in Parallel connection with the iPad battery
my board level repair is not micro-soldering
please more info about the tristar chip
Edit : i forget after adding the iPad battery the standby time pumped up to 10 hours without using but with using its still 3 hours limit
完成的
添加一条评论
First thing - check, what applications are running, and try to close all of them. I found that some applications kill my iPhone 5 in about an hour (even though application is not actively running, screen is off, etc.).
Second thing - check if you have "Find my iPhone" enabled. That's what was draining my battery. With this service running, my phone does not survive through the day, while if I disable it, I have more than 50% at the end of the day.
Good luck,
Mike | Headset Adapter Co.
这个答案有帮助吗?
得分 0
1条评论:
i did almost all these stuff it does not change the fact only max time in usage is 3 hours and at most 15 more mins
完成的
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 63
