跳转到主内容
电脑制造商联想所生产的台式机的维修和支持指南。
75 个问题 查看全部
One half of monitor screen is tinted darker(as if for night)
Right down the middle of my (LG) monitor), one side is tinted darker than the other. During the day the tinted side looks more purple, at night it is a tan-ish tint. It is still possible to see graphics and read text on both sides. My desk top computer is a Lenovo. How do I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Hi @kkellys ,
Have you tried another monitor just to prove that the problem is in the monitor and not in the computer?
Can you try a different video cable, just to eliminate it as being the problem as well?
完成的
添加一条评论
4个答案
最有帮助的答案
Hello jayeff - We tried the monitor on another computer and determined the problem was in the monitor. I had inadvertently made that nasty setting and discovered the fix while investigating other potential monitor settings. I didn't know the monitor had its own settings. Thank you for offering your suggestions!
这个答案有帮助吗?
得分 1
3条评论:
Hi! I have the same problem. Which monitor do you have, and how did you fix it? (I have an AGON ag352ucg6)
完成的
Hi there - I have the same problem, how did you fix it??
完成的
For me, with a Lenovo monitor there is a setting for the screen on the monitor itself ... Text, Web Pictures, something else, Split Screen ... I had set mine inadvertently to Split Screen by fumbling with the "buttons" (places on the bezel that are touch sensitive) and corrected the problem with more fumbling with those buttons.
完成的
添加一条评论
this problem is caused by the dead USB or bad driver which cannot be reconigationed by our pc so I can give you a solution for this problem
1. Turn on your pc or laptop in safe mode.( go to setting and go to security and advance setting then select restart)
2. Don't use dead or virus usb or driver.
3. make you pc’s brightness no more then 25%.
4. Give some rest to your pc after every single hour.
这个答案有帮助吗?
得分 0
1条评论:
I connected a bad USB to my pc and noticed half of the screen is tinted yellowish. Can you provide more details to restart in safe mode?
完成的
添加一条评论
maybe the reason is in the monitor settings. enter them (using the buttons on the monitor) and reset to factory settings
这个答案有帮助吗?
得分 0
添加一条评论
hey there!! there is a button named as autoset in your display settings, click on the button and set the option to normal, otherwise look for a factory reset setting. hope it helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Karen Sigworth 将永远感激不已
浏览统计数据:
过去 24 小时: 17
过去 7 天: 125
过去 30 天: 543
总计 22,526
