跳转到主内容
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
61 个问题 查看全部
Is this a battery leak?
I opened an iPad Mini earlier to replace the screen and found a shiny coating on one end of the battery. Does this look like a battery leak?
The coating is already dry and feels fairly smooth. It only appears along the top of the battery along the edge that's exposed under the LCD shield plate. There's no sign of fluid below the battery or elsewhere in the iPad. This device has been repaired before.
If it's not from the battery, is there anything else in there that might leak? The LCD looks fine. There were no reported battery issues, either.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
That does not look right.. Looks like something melted at the bottom of the battery.
这个答案有帮助吗?
得分 0
添加一条评论
Yes, you will probably have to replace the battery and any components that have been damaged by the leakage.
It looks at though the battery acid has dried up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ket 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 910
