跳转到主内容
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 个问题 查看全部
Why isn’t my phone turning on?
i didn’t do anything i just turned my phone off and then after when i tried to turn it back on it stayed off and when i put my charger in it doesn’t say it’s charging. i haven’t dropped it or anything. what should i do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Remove Battery and then plug into charging cable. Try and power up. If this works the Battery is dead and needs to be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
unfortunately the phone will not power on without a battery in. Try replacing the battery. If that does not work you most likely have a logic board problem, which is common over time with a phone that old.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
urie diculous 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 55
