跳转到主内容
于2016年3月上市。型号 SM-G930V。
425 个问题 查看全部
My phone is charging weirdly.
About a couple of months ago I noticed that my phone wasn't charging properly, going from charging to not charging frequently. I tried with brothers charger in his room and it worked fine, so i went and bought a new charger for my room. It was fine for a month and then today i noticed that it wasn't charging with the new charger. I tried rebooting my phone and other options but to no avail. It works with chargers downstairs but not in my room. Is this a charger problem or is it my phone? This is the 3rd charger this year so far.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Have you tried another charging cable?
Sounds like different wall chargers being used but cable hasn't been changed yet for your room.
这个答案有帮助吗?
得分 3
2条评论:
I've tried multiple cables but so far they die within a month in my room, i'm buying another one soon, probably from Samsung but i'm not sure how long it'll work for
完成的
I'm going to take a guess it's the charging port in your phone making them go bad, but this is only the case if you can tell the charging cable plug is melting or you smell electrical burn / burning plastic when you plug the charger in and unplug it on multiple cables.
完成的
添加一条评论
Check if the charger in your room is a good quality charger. Never buy cheap chargers for your phone or anything else. Buy one that Samsung makes.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Max Black 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 11
总计 1,070
