跳转到主内容
The 3DR Solo is the first smart drone released by 3D Robotics in April 2015. The 3DR is built for use with an action camera to produce landscape Aerial shots.
6 个问题 查看全部
Why is it not powering up to stay on
My drone flipped over onto its side just at takeoff. The back left propeller just the end broke off. The next time I flew it that same motor at first started up slower. Now when I turn my drone on I hear a click (just 1 click) and it wont power on at all.
Is there a reset or something more I can try to troubleshoot to get it going?
I am a first time owner of a drone.
Thanks Tim
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Hello Tim, I have the same problem, you managed to fix it ??? please help
完成的
Hi Tim, this issue is normal when a motor fails. Effectively the prop motor board has burnt out and that need replacing .
https://www.ebay.co.uk/itm/3DR-Solo-Dron...
There is a posibility that there is an obstruction stopping the motor rotating.
完成的
添加一条评论
1个答案
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tim B 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 222
