跳转到主内容
Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
What is the max amount of ram this can take?
Hi as probably you all know most Macs can have more ram than what Apple says it can have so I’m here to ask if this Mac mini can take 2GB of ram instead of 1GB? I’m not sure if they make any 2GB DDR ram card so I’m not sure if it would work cause it only has one slot.
Let me know what you think. I have 1GB installed currently on my 1.5GHz 10.4.11 Mac mini.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Your systems specs: Mac mini G4 1.5 GHz
完成的
添加一条评论
1个答案
已选择的解决方案
All of the PowerPC based systems can only address 1 GB of physical RAM. At the time the systems video graphics had a fixed memory address just above the 1,048,576 KB mark and couldn't be shifted.
Between the system CPU and firmware and the way the OS worked in these older systems you couldn't add more memory like we can today.
这个答案有帮助吗?
得分 3
4条评论:
Ok. Great just checking. On the activity monitor it says I have 2GB of virtual memory and 1GB physical memory. Is virtual memory hard drive space acting as ram?
完成的
It also says I have 64MB of graphics memory.
完成的
Yes virtual RAM is storage space acting as RAM (HDD or SSD)
The 64 MB of graphics RAM is fixed at a set memory address, which is why you can't add more RAM even-though the memory addressing of the CPU could in theory access it PowerPC G4.
完成的
Got it. Thanks for the info.
完成的
添加一条评论
添加你的答案
Padraic Hoselton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 430
