跳转到主内容
The HP Pavilion model dv7-4285dx is a notebook PC produced by HP.
8 个问题 查看全部
How to clean the fan
My laptop is overheating and i can feel the heat through the case and so l eventually came to the conclusion that the fan is not working but because dust is trapped in the machine. And originally, i was planning on taking it to a computer store so they could clean the fan but I'm trying to save a dollar or two by doing it myself.. Does anyone know how to go about doing that, safely? Because i don't want to destroy my laptop. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Unplug. Switch off. Let it cool down for tens minutes. If it is really dusty strip it down to Step 12.
HP DV7-4285DX LCD Replacement
If you are not confident to take it apart. Just use your vacuum cleaner on the rear & top vents. Preferably with a small brush attachment (if you have one)
这个答案有帮助吗?
得分 0
添加一条评论
I applied colgate on my CPU while I was cleaning my motherboard with spirit. After that my laptop could not switch on and the fan is not even turning around. What should I do? Can it be reversed
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AJS 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 676
