跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Stage Light Effect on Display Screen
With my horrendous luck I noticed this issue just a week after the 1 year warranty of my Macbook Pro ended.
According to my research this issue can stem from 3 things:
1) a faulty LED-Backlit display in which case will need to have the whole display replaced
OR
2) LVDS 'graphic cable' issue, either it needs to be
--replaced
--or just repositioned
At this point in time I'm leaning more towards bringing it to an accredited Apple center for repair.
My question is, can anyone tell me the range for fees and for how long the repairs would be for each scenario mentioned above? Just a minimum/estimate would be fine so that I won't be quite shocked when I do bring it over to the center ><
And is this an issue that I can just ignore, practically speaking? Would it get worse if I leave it as is(like bigger shadows or whatnot overtime)?
On a side note, I also noted keyboard issues popping up after this. Sometimes the letter 's' would have a lag, won't be functional or would double type. Same with the no. 2 key. I'm not sure if this is related or an entirely different problem with the display -- no other functions seem affected
MacBook Pro (13-inch, 2016, Two Thunderbolt 3 ports)
Processor: 2 GHz Intel Core i5
Memory: 8 GB 1867 MHz LPDDR3
Graphics: Intel Iris Graphics 540 1536 MB
- picture taken at the lowest screen brightness
- increasing it appears to lessen the shadows but they're still visible even at maximum brightness
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
15条评论
FYI - The cable is just called a display cable now as the signaling is no longer LVDS it's now using internal Display Port (iDP). All Retina displays use this newer signaling method.
完成的
Please sign the petition https://www.change.org/p/apple-fix-all-m... to let Apple fix such faulty machine. I am also facing this problem.
完成的
I am also facing this problem, contacted apple support and they told me to get it fixed by a third party. Don't do this! because if you do and they acknowledge this hardware problem you won't get a refund.
完成的
I have the same problem.I wrote the Apple Support.But Apple says I need to replace new screen and it is approximately 650 US Dolar.I can’t afford it and I don’t want to pay a lot of money for Apple producing faulty.I don’t know what I will do.
完成的
Join the club! #flexgate
Sadly there are no options ;-{ You need a new display assembly! I would get to an Apple Store and press them on the fact this is a product defect!
The Design Flaw Behind MacBook Pro's 'Stage' Light Effect
完成的
显示更多的10条评论
添加一条评论
12个答案
已选择的解决方案
just1ed - Here's an image of the cables that interconnect the display to the logic board I call them cables, Granted they are more spring than cable but they are the means the electrical signals move between the display & logic board on the newer Function Key models. These are the failing pieces. The single cable you are talking about from the displays logic board to the main logic board it's self might also be a possible failure point but these two cables are more at risk of damage.
Here’s a clearer picture and commented with descriptions of the parts:
这个答案有帮助吗?
得分 5
6条评论:
I'll try and see but these two cables do not connect to the logicboard. These connect to the display, and are held in place to the Macbook's metal frame with screws at the spring areas. No signals are transferred from the logicboard to the LCD. It'll be strange if they are the ones causing the issue but I'll teardown and see what goes.
完成的
@danj I have down a teardown. The information given by you is incorrect.
1. The two cables you have circled which have the spring mechanism do not connect to the logicboard. They connect to the display's IC board and are soldered on.
2. They are not removable.
3. There are two smaller ones, one which is responsible for the LED light, are removable only on the LCD I/C board but are not removable from the LCD side.
In summary, I am high suspect Laptopblue.vn fixed the user's issue by changing any LCD cables.
@danj If you have fixed the issue by replacing the display and not the LCD cables, giving advice about a query I made on LCD cables is redundant.
完成的
Your own image below states differently!
完成的
I reseated the connections and that worked! Thanks for posting this.
完成的
I guess it's not a cable problem, at least for me, since it not occur when the background is not white. Iam having stage light effect only when the browser (Safari or Chrome )is open with white background at bottom
完成的
显示更多的1条评论
添加一条评论
As shown here, the cables mentioned by @danj cannot be swapped out. I have pried open the clutch cover which is glued to the LCD bottom panel to investigate.
These are the components, labelled, with clear explanations of what they do and how they are connected.
This should answer anyone's queries about whether the LCD cable can be changed. The part that can be changed is not the answer. The parts that might be the failing ones, cannot be changed.
Conclusion:
1. Apple needs to initiate a recall.
2. LCD display change is the only solution for now.
这个答案有帮助吗?
得分 3
8条评论:
I think you misunderstood what I stated!
"The problem is either in the display (expensive repair) or the backlight LED driver chip has a problem (again an expensive repair)."
I stated very clearly the complete assembly needed to be replaced. My point was to explain what failed not that the cables could be replaced.
The bottom line here is we both agree! And this is a design defect which Apple needed to cover under warranty!
完成的
Got it. I think the misunderstanding was due to the statement you made there are " two cables that interconnect from the lid logic board to the main logic board" and posted the reply to the question I asked Tyler about which cable was replaced. That's incorrect though. The two cables that you have circled do not connect to the logic board at all. They are merely mounted on the case.
完成的
My 2016 MBP 13" retina display has just failed at 18 months due to one of these cables going open circuit. It showed the "stage light" effect for a while before that.
Looking at the design of the connections, it seems marginal to me. The bend radius of the flexible PCBs is about 2.5 mm, and from the design literature I could find, you need to be doing everything exactly right to get a long life connection with this radius - i.e. one layer of the thinnest feasible Rolled Annealed copper placed exactly at the neutral point of the bending axis may give you an mean life of around 1 million flexes. If anything is slightly off in the design or manufacture (such as the copper not quite being at the neutral point), then the mean life drops dramatically, maybe to 100000 or even less. If you are unlucky as well, and land somewhere away from the mean on the normal distribution failure curve, then maybe it will fail at around 10000 flexes, which would seem to be my situation.
This would be less of a disaster if the cables were replaceable.
完成的
This is the kind of engineering a trillion dollar company is producing. It is very widespread, even more so than the keyboard issues. I am surprised there's no class action suit launched against Apple, and that there's no product recall or free out of warranty replacements.
完成的
I'm not sure I'd blame the engineers - it's more likely a product design and management decision for a company to compromise reliability in favor of thinness, and something that doesn't have a direct impact if your warranty is only 12 months. (In my view a 5 year warranty would be more reasonable for a top-of-the line laptop or phone.)
完成的
显示更多的3条评论
添加一条评论
Stage light effect is usually caused by a loose or broken display cable. Sometimes it can be resolved just by reseating it. I think that if the display cable is bad, you would most likely looking at a whole new display assembly.
The keys however, are the design flaw of the 2016 MacBook Pros. Usually they replaced the keyboard under warranty. Sometimes keys can be remedied by blowing them with a compressed air.
Take it to Apple and try to get them fix the machine.
这个答案有帮助吗?
得分 2
7条评论:
Agreed the keyboard issue should still be under the extended warranty program Apple has for the keyboard.
As for the Display thats a bit iffy... Unlike the older generation the cable is less likely to shift. Review the 带功能键版本的 MacBook Pro 13寸 2016年末款拆解 Step19. More likely the cable is severed! That will require a new display. I would think Apple would cover that as well!
完成的
Yeah, I'm bummed now because I also just got a reply from an Apple Accredited Service Center and they immediately told me that the whole LCD would need to be replaced -- which they estimated to be around $600 with labor.
Unfortunately for me the 1 year warranty ended just last February 4, I forgot to purchase Apple Care which I was planning to do, so now I'm in deep doo-doo >:(
完成的
You should still try to get it covered! I would go to an Apple Store as they tend to be more willing to cover these types of issues. Go in mid morning on a Tuesday or Thursday as these times they seem to be less stressed. Be pleasant but firm. Focus on the keyboard issue (dim the screen so the screen issue is less visible). If they cover the keyboard problem your golden! Then when you pick up the system raise the screen brightness to see if they fixed it, if not bring it to their attention for a re-work.
完成的
@danj @oldnewstuff Does this issue escalate the longer it goes on? Like the shadows worsening and lengthening? I mean, I guess I could live with it, as long as the shadows stay low on the screen then it doesn't really bother me much compared to the ~$600 i would cash out for the repair. Otherwise, i won't have a choice but to have it repaired if by some time the issue would extend beyond the lower borders ><
完成的
@skmm - The problem is either in the display (expensive repair) or the backlight LED driver chip has a problem (again an expensive repair). If you let the warranty expire its going to cost you $$
完成的
显示更多的2条评论
添加一条评论
FYI, I just got mine fixed at a MacBook Pro repair shop in Saigon, Vietnam (big shout out to Laptopblue.vn aka Applefix.vn).
The most amazing thing was they found out that only the display cable was damaged, absolutely nothing was wrong with the LCD screen itself. They did a great job and my screen is working as good as new again. The cost was $50.
Prior to going to this shop, I went to two Apple Authorized Service Providers and they both wanted me to replace the entire display assembly as some of you here had encountered. I suspect this was a strategy employed by Apple to extract more money from their loyal customers. Shame on you Apple!!! I will never buy another device from them ever again.
I know some of you may encounter this issue in the future. You don't need to replace the LCD, you'll just need to fix the display cable.
Don't give Apple $600 of your hard earned money. They don't deserve this.
这个答案有帮助吗?
得分 2
5条评论:
@Tyler+P. May I know exactly which cable was replaced? Many of my customers have this issue, except that their issue is accompanied by an issue where the screen goes to black when it is pushed up after a certain angle.
We have tried new LCDs with the existing LCD cable and it isn't an LCD cable issue. The LCD cable itself does not flex or move (it is secured in place horizontally by screws) .
完成的
@tyler p . bro i am having the same issue with my macbook A1708 , screen goes blank after opening the lid beyond 30 degree angle. i took it to icare and there are asking for a screen replacement cost $700. please share if you have found a solution. thanks
完成的
@just1ed .bro i am having the same issue with my macbook A1708 , screen goes blank after opening the lid beyond 30 degree angle. i took it to icare and there are asking for a screen replacement cost $700. please share if you have found a solution. thanks
完成的
Same issue here and they also want me to pay 700 to change the whole display. Trying to take it up the food chain to see if <i can get an exception or if we can start a repair program... Any updates on what has happened to other folks?
完成的
Guys I got my MacBook repaired about 3 months ago free of cost from apple, they have replaced the entire screen assembly.They are now running repair program for stage light effect problem.
完成的
添加一条评论
Sign this petition https://www.change.org/p/apple-fix-all-m... to let Apple repair these faulty machines.
这个答案有帮助吗?
得分 2
添加一条评论
So I have this issue too. I asked for an exception from Apple and they basically told me to go &&^& myself. I shared this thread with them to show that this is a very widespread issue. Didn’t care.
The most amazing thing though was the excuse they conjured up to not pay. They took pictures of the LCD cable which is obviously completely &&^&@@. They then send these to me and say that it’s ‘accidental damage’ and therefore there’s no way they can help me because they only cover functional damage. I ask how it could be possible that I accidentally damaged an LCD flex cable that is inside the housing of the machine. Their answer? That it must have been opened up by some mysterious third party and damaged maliciously. I emailed them to say this is completely absurd, and they just ignored me.
Roll on the lawsuit I guess.
这个答案有帮助吗?
得分 1
1条评论:
I hope you can escalate to a senior advisor, they cannot prove whether it's been tampered by a third party unless a third party person reassembled the machine poorly or third party parts are found in there. If it's accidental damage, there must be exterior signs as well.
https://www.youtube.com/watch?v=o2_SZ4tf... (similar repair but older model, my guy just did something with the cable)
完成的
添加一条评论
I had exactly the same issue, I replaced the whole LCD screen assembly and it works again. I hope I’ll not have the same problem in the future. If it’s the flex cable that fails it can fails at anytime even if the whole LCD screen assembly has been replaced.
It’s not very ecology minded from Apple to force their customer to replace the whole screen assembly when it’s just a flex cable that fails. For a company that communicate about being “green” it’s not very consistent. And that’s really not what I expected from a 2600€ laptop.
Anyway, I hope future model will not have the same flaws, and I say that already knowing that the 2018 model have the same design, so it’s not a good news.
They have fixed the keyboard flaws years after year, but the screen backlight seems not to concern them. Maybe it’s less visible, maybe it’s not as frequent as the keyboard.
Well, I hope so for my screen !
这个答案有帮助吗?
得分 1
1条评论:
I highly suspect it is because the keyboard issues are clearly visible, harder to deny fault, and is cheaper to replace. To replace the LCD would cost the company too much. The cables are likely overstretched. It is bad quality and design, period. Running LCD flex cables on the OUTSIDE of the hinge is unprecedented.
完成的
添加一条评论
same problem here with a MBP late 2016 , I bought it in Miami and I live in Brazil. It's frustrating dedicate extremely care for a computer and watch it breaks by itself, in normal use. Apple, please, recall everybody, at least from 2016 to solve this common issue.
这个答案有帮助吗?
得分 1
添加一条评论
This is my experience, my MacbookPro 13" Touchbar 2016 just started having this backlight issue at the bottom of the screen right after a few months of warranty.
Also when I recalibrate the screen, I found out that the maximum brigtness has decreased to a max of 165-175 cd/m using a i1 Display Pro (i1D3) with their supplied i1Profiler.I always calibrate my screen to 120cd/m, when I first got it, 120 cd/m is about 65-70% screen brightness using the slider in System Preferences > Displays. Now 120 cd/m is about 90% screen brightness.
I’m going to give @Tyler+P. vendor a shot since I’m currently in town as well.
p.s: I know for fact that once I take it to Apple or even if Apple decides to offer repair program on this I’ll be out of luck as they will blame that it’s related to this cosmetic crack caused by a headphone jack left sandwiched between the lid and the body.. F this.
这个答案有帮助吗?
得分 0
9条评论:
With further investigation the cable is soldered to the LCD assembly and can't be replaced discreetly. Of the two display units I've pulled apart the ribbon cable was damaged and could not have be saved. Sadly you have little recourse here other than replacing the complete assembly.
I suspect Tyler+P had a dirty or loose connector interface which is why he was lucky. This is becoming a big problem for Apple right now as too many systems are encountering this failure across both the Touch Bar and Fn models across 2016 onwards, as they all use the exact same design (both the backlight & data cables are failing). Review Just1ed pictures for the details.
完成的
I'll report about my case later after taking it to a known repair shop in town. Does anyone else notice a decrease in peak brightness as well?
完成的
@longpvo - I got a fix for that damage ;-} The chin plate is just stuck on and can be replaced! Here's a guide someone made for the 15" model MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement. Here's the needed part Display Chin Plate. I would fix this first so the cosmetic issue is not visible to them.
The brightness loss is do to the fact only 1/2 of the backlight LED's are not working.
完成的
That’s neat. Thank you Dan. I already had that replacement part around, last time the repair guy thought it’s too fragile of a job to perform have so he recommended not to.
完成的
So my repair shop fixed it for 100$ bucks without taking the display apart, it's still a significant saving.. Peak brightness came back too 500 nits. They didn’t dare to take off the Display Chin Plate so I ended up cutting some 3M tape and did it myself.
I really think Apple should acknowledge this like the keyboard issue ffs. It's a known issue.
完成的
显示更多的4条评论
添加一条评论
They will also try and cover the cost if you had to pay out of expense and reimburse you (I believe if you've done repairs with apple and not a third party) All the info are on the website
这个答案有帮助吗?
得分 0
添加一条评论
Even i have this the Stage Light Effect issue :( on my 2017 MBP 15inch )
Lets file a law suite , there are many more users with this issue , lets gather them all , this is so unfair my laptop is in pristine condition and has always been used indoors with an external monitor.
APPLE NEEDS TO ISSUE A RECALL
这个答案有帮助吗?
得分 0
添加一条评论
I found a solution by scraping down to the traces and soldering them thick solder. Worked for me : )
这个答案有帮助吗?
得分 -1
4条评论:
This is a solution, but I would use some thin flexible wires instead of thick stiff solder that would break again with use.
Or just force Apple (class action if needed) to replace all of these screens for free with improved style ones,
完成的
Please read both of these IFIXIT reports:
The design flaw behind the MacBook Pro's "stage light" Effect
Apples 2018 McBook Pro's Attept to Solve Flexgate, Without Admitting It Exits
Patching the ribbon won't solve the problem only delay the inevitable. The risk here is if your patching fails it could short out damaging the logic board as well!
完成的
Well, it's been 30 days so far and I haven't heard back from her yet. They definitely be back I do imagine. I will follow up once that happens. If no follow up I would assume that it is still fixed and fully functional.
完成的
@tonytone - This is not a reliable repair as the wires will also snap. I've now seen three of these systems which someone has patched only to tell them I wouldn't fix the system as this repair is not the level of quality I preform, I offered the proper repair options and they all declined given the age of the system and the butterfly keyboard issues.
完成的
添加一条评论
添加你的答案
skmmanuel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 81
总计 65,172
