跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
Screen Repair - LCD Plugs into Logic Board
I am trying to plug in the final plug into the Logic Board and am having trouble. It will click and then unplug itself nearly instantly. Help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Sounds like one or both sides of the connector have been damaged. Take a look with a magnifying glass.
完成的
添加一条评论
1个答案
assuming you got a high grade part. (oem standards are the best you can get) Then the issue may be with the connector on the board. also, you will need to hold the screen vertical for the best effect of installation. dont try to connect the screen while its laying down.
You may have also gotten a screen with a defective Connector, in which case, your suppliers warranty should cover it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Drew Titus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 68
