跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 个问题 查看全部
iPad randomly restarting and WiFi grayed out
Hello, my problem is my iPad will randomly reboot, when it comes back on the WiFi will be grayed out and I am unable to turn it back on. Only after several restarts does it work properly....for a little while. I have already replaced the WiFi antennas and factory restarted it so that can’t be the problem. The problem started when I tried to use my aunts charger on my iPad, a charger that I didn’t know was a fast charger, my theory was that it overloaded the iPad with power. Don’t know if that’s the case but what ever it is, how can I fix this?? Thank you in advance for any help you can provide.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I have the same problem with an iphone 6, I also replaced the antenna and it’s doing the same... In my case, my phone got a little wet from the rain, and it started to behave this way, so maybe an overshoot in current is causing it... were you able to fix it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steven 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 305
