Screw diagram (actual size) for iPhone 6 Plus screws.
Is there a printable mm chart available (actual size) to determine the sizes for the iPhone 6 Plus? I ordered a complete set and they all came jumbled up together!! Thank you!
Hi!
You can print out this image and then follow this guide first to organize the screws by similar sizes (measure them with a caliper if possible), group quantity, and sort them by chart color.
Hope it helps!
Christian
这个答案有帮助吗?
Thank you so much Christian! This is going to help tremendously!
Best regards,
Jason
Hi! I just ordered a set of screws for iPhone 6S and a caliper to measure them because I lost a few screws doing my first repair.
If I'm looking for a 1.2mm screw, is that the thread length, the whole screw length (from top of head to bottom of thread) or the diameter?
If you have the images on your computer (or if you can scan them in) you can use a program called Inkscape. This is a free vector drawing program, but the neat thing about it that makes it useful to you is that you can set up the page to be the size of the paper, you can put all the units in mm, load the image into it, and scale it such that it is 1 to 1 in millimeters, save it as an image you can print, and print it (disabling any stretching, fitting to page, or boarder protection features to make sure the image doesn't get resized in the process. You could make the image just big enough for the image of the print, add in inches marks as a guide, and put the image in a word document and line up the guide marks, and then print it from there so you don't have to mess with any scalling settings built into the printer).
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 48
总计 19,815
