跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Screen not turning on
After screen replacement my screen won’t turn on. The phone was switched of and the repair was done. When the new screen wasn’t working I tried putting the old cracked one back on it but it didn’t work either. I’ve done lots of screen replacements but have never come across this problem. I have tried everything but cannot find any fixed please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I’ve tried using a flashlight too see the screen but I cannot see anything but the phone is turning on because I can hear the noise from charging the phone and it vibrates when putting ot on silent
完成的
添加一条评论
1个答案
已选择的解决方案
Did you forget to unplug the battery?
Backlight failure is a very common issue on the 6s models in particular because of the 4V pin and the ground pin on the LCD connector being next to each other can can be shorted easily when connecting or disconnecting the screen with the battery plugged in (even with the phone and screen turned off).
Usually you will see a puff of smoke near the screen connector when this occurs.
To confirm backlight failure, turn the phone off and use a flashlight to see if you can see a dim apple logo on the middle of the screen, additionally you could connect the iPhone to a computer and open up iTunes to see if the phone successfully boots up and is detected by iTunes.
To get backlight circuit fixed, that requires someone to do micro-soldering on the phone (basically repairing the backlight circuit and components on the logic board).
I would estimate about $80-$150 for the job to be done.
这个答案有帮助吗?
得分 2
3条评论:
完成的
Then it's either a faulty screen or micro-soldering need to be done on the board at least.
TL:DR - Phone most likely needs to be looked at someone that does micro-soldering to troubleshoot no display / backlight issue if multiple screens have been tested already on the phone.
完成的
Alright okay, thanks.
完成的
添加一条评论
添加你的答案
Haris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 91
