跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for cash registers.
Register has error coed of printer error
Every time the tape is changed there is an error code of printer error and it is a nightmare to get the register to start working. We are unable to find anyone to repair the problem. This is a Royal 9155sc register
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
My Uniwell electronic cash register is not printing
完成的
Error check printer code how do I clear
=== Update (04/26/2022) ===
Error check printer clear
I need to clear
完成的
添加一条评论
2个答案
最有帮助的答案
Sounds like it could be a few different things:
1. There is some shred of paper somewhere that is jamming your paper feed just enough to be a problem. (not likely)
2. Are you pulling on the paper by hand or hitting the "feed" key? Manually pulling on the paper is not recommended and can cause issues.
3. Check the bottom of the paper well (the cavity the paper sits in) and ensure nothing is laying in the bottom of the well. I've seen where the plastic spindle has remained in the well when inserting a new roll and has caused issues.
If you have tried and/or observed that none of the above is the culprit, please describe what steps you have to take to make it start printing again? I'm also assuming you tried just hitting the EC key when the error appears?
这个答案有帮助吗?
得分 2
1条评论:
We have tried all of the above but I agree that there is something in there causing the problem but I have even tried blowing it out with a hair dryer etc. The only thing that makes it start working again is to do a half clear of the register and we cannot do this everytime the paper is changed. This is a really easy register to work and to program I hate to just throw it out.
完成的
添加一条评论
How do I remove printer error on unwell cash register manual
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
M. Miles 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 45
总计 8,106
