Sliding Door Lock broken
Approximate cost to repair?
Ive had this done recently. bought the part for $50 on ebay, labor was $650. I hired a really really good mechanic who had never done this specific repair before. it took him 5-6 hours. he could not remove the door all the way so he removed the back hinge and propped the door so he could work on it. he had to remove practically everything from the inside of the door before he got to the part. then put everything back in it. i was afraid he was accidentally going to break something the whole time. He complained about how hard it was the whole time. fortunately it works perfectly now, but there are some scratches on the window. not sure if that could have been avoided or not. if i could do it again i would have had the dealer do it.
这个答案有帮助吗?
I had a similar issue (I couldn't lock or unlock the door) and ultimately just had to order the actuator to replace for like $50. You can do it yourself if you feel comfortable taking the door panel apart (be careful of the window because I unwound it on accident and it was a pain to fix) or you could pay for a mechanic to do it for probably about what others were quotes ($650-$1000)
这个答案有帮助吗?
Beware. chrysler had a recall for this door lock for some models, you could get it for free look at the requirements “Chrysler Town and Country door lock recall”
You can do this yourself if you feel comfortable removing the door panel.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 26
总计 1,647
Can you lock the door manually? I have the same issue, at least with not being able to lock it remotely. I am planning to replace the actuator soon which would be about $100. The dealership quoted me about $1,000 to fix it.
由 Bill Sullivan 完成的
