跳转到主内容
Released in February 2012. Model number: DSC-H55.
Why is my computer not reading videos from my camera?
I use Windows 2008 and my computer doesn't read videos from my camera. It sees photos no problem, but videos are invisible. It shows only that the memory card is full, but there are no files, yet you can still watch the preview of the videos on the camera itself. It works only with my mom's laptop and only when I pull out the memory card and plug it directly to the laptop, because it doesn't read the videos through the cable.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @dragonixa ,
What is the OS in the computer? Do you mean Win 8 or Win 8.1?
What program are you trying to view the videos in?
If you are using Windows media Player 12 mpeg-4 will not work. This format is what the videos from your camera use.
Download, install and then try using a 3rd party media player and see if this resolves the problem
这个答案有帮助吗?
得分 2
10条评论:
It's Win 8. I simply use USB cable to try and import photos and videos by opening the Memory Card folder, but my computer only sees photos in that folder, like there are no videos recorded, while they clearly are...
完成的
Hi @dragonixa
Check to see if the videos are in a "hidden" folder on the camera "drive"
Did you format the card in the camera or in a computer?
完成的
I turned hidden folders visible and still nothing... About the format - I have no idea. But as I written in the description of my question, when I plug the memory card directly, not through the cable, it suddenly works. Maybe there's something wrong with the cable then? Don't know
完成的
Hi @dragonixa ,
Try another cable then or try another USB port in your computer (if you have one).
What OS is in your mother's laptop, as you said that it works when using a cable (presumably the same one) with her laptop?
完成的
No, it doesn't work with the cable on her laptop either. Only when I plug the memory card directly to the laptop
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Kamila Haas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,025
